Ga door naar hoofdinhoud
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
20 Vragen Bekijk alle
Battery and charging issue
I did a battery replacement on 6 iPod touch 6th gens. All devices power on after replacement but all the batteries still lose battery life within minutes. Also when you plug them in to charge it indicates charging but even after leaving each one charged for an hour or more the battery percentage does not go up whatsoever even if you hard reset the iPod. Tested each battery and all of them were around 3.8v mark. iTunes does recognize the iPods when I plug them into my laptop. The batteries I used were of a lesser expensive type as opposed to say the ifixit batteries which I just purchased to try because I think these would be of a better quality. Has anyone had this issue? I’m guessing since the charger port works and it recognizes iTunes that the charging port would not be suspect. Any insight would greatly be appreciated.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Were the batteries you purchased brand new? As lithium ion batteries age, they lose their ability to hold a charge.
Was dit antwoord nuttig?
Voeg je antwoord toe
Barnaby Levitin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 9
Altijd: 355
