iPad 5 charges when powered off; testing data included
I have two iPad 5th generation tablets (data/GPS), one 10 W OEM charger and one 12 W OEM charger with many OEM lightning cables.
One of the iPads charges very slowly and only in a certain connection. I bought it used with this problem. It otherwise functions normally with normal battery life and battery % display is normal. I have not opened it but there is no obvious sign of damage. The charge port was cleaned by me but not much was pulled out. The contacts were lightly cleaned with IPA, no obvious sign of damage to the contacts is seen either. I haven't had any trouble syncing/backing up with iTunes. A DFU restore was also performed but made no difference.
Using a USB ammeter which also gives the state of the data lines, the following info was gathered. The ipad is approximately 55% charged during these tests. Similar results are found with the 10 W charger and combinations of charger/cable. The other tablet charges just fine with these accessories.
12 W charger; no device plugged in
A: 0A
V-: 0V
D-: 2.77V
D+: 2.76V
V+: 5.18V
Ohms: 999.9
Watts: 0W
12 W charger; faulty iPad powered on, same result if in sleep or wake state
A: 0A
V-: 0V
D-: 2.74V
D+: 0.07V
V+: 5.18V
Ohms: 999.9
Watts: 0W
note: Upon plugging in, the iPad briefly wakes up and displays "Unlock iPad to use accessories"; no charging icon is seen.
note2: sometimes the result of this test was:
A: 0.06A
V-: 0V
D-: 2.74V
D+: 0.09V
V+: 5.18V
Ohms: 86.33
Watts: 0.31W
with no "unlock" notification but still no charging icon
12 W charger; faulty iPad powered off after plugging in to charge (if I plugged the tablet in when it was powered off, it would power on)
A: 0.47A
V-: 0V
D-: 2.65V
D+: 0.21V
V+: 5.17V
Ohms: 11
Watts: 2.42W
MacBook Pro; no device plugged in
A: 0A
V-: 0V
D-: 0V
D+: 0V
V+: 5.03V
Ohms: 999
Watts: 0W
MacBook Pro; faulty iPad powered on but in sleep state
A: 0A
V-: 0V
D-: 0V
D+: 0V
V+: 5.03V
Ohms: 999
Watts: 0W
note: Upon plugging in, the iPad briefly wakes up and displays "Unlock iPad to use accessories" notification pops up
MacBook Pro; faulty iPad powered on but in wake state (screen is unlocked)
A: 0.95A
V-: 0V
D-: 0.16V
D+: 0.17V
V+: 4.86V
Ohms: 5.11
Watts: 4.61W
MacBook Pro; faulty iPad powered off
A: 0.47A
V-: 0V
D-: 0V
D+: 0.14V
V+: 4.95V
Ohms: 10.53
Watts: 2.32W
The results on the MacBook were similar for both iPads.
With the charger, the normal iPad charges like this:
12 W charger; normal iPad powered on but in sleep state
A: 2.00A
V-: 0V
D-: 2.65V
D+: 2.65V
V+: 5.13V
Ohms: 2.6
Watts: 10.1W
note: no notification pops up
12 W charger; normal iPad powered off after plugging in to charge
A: 1.89A
V-: 0V
D-: 2.65V
D+: 2.65V
V+: 5.13V
Ohms: 2.7
Watts: 9.7
It seems there may be a problem on the D+ line. It drops to low voltage when a charger is plugged into the faulty iPad. I think this then makes the iPad think it shouldn't draw much power. The best way to charge (0.5 A) is from a charger when powered off.
If this is definitely a tristar/tigris problem, I probably won't attack it myself but if you think this could be a connector problem then I may try to fix it myself.
Thanks for any help.
Is dit een goede vraag?
1 Opmerking
I just did these tests again and realized that the D- line is the one that drops. I don't know if these are different results or if I made a bad record keeping mistake. Regardless, I'm sad no one has any input.
door Quinn
