Ga door naar hoofdinhoud
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Vragen Bekijk alle
MBP 15" 2.66 Ghz Mid 2009 losing time after battery drains
The said MBP resets its system time after a shutdown when the battery is drained. I know some macs have a PRAM battery. Does this MBP (MacbookPro 5,3) have a PRAM battery too? Or can this be fixed by replacing the regular battery (which is not in its best shape, almost 50% of the original charge)?
Is dit een goede vraag?
Score 1
1 Opmerking
Hi Marco,
Did you discover if this model of macbook pro has a PRAM Battery and if so, where exactly it might be located.
Many thanks,
Darren
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sounds like it's time for a new battery and PRAM battery.
Was dit antwoord nuttig?
Score 1
Hey Marco,
Yes it should do, It wouldn't be a part of the actually battery as if your actual battery runs out, it wouldn't keep the time anyway.
best thing you can do is safely remove the bottom case and it should be fairly obvious thing to spot.
Enjoy and good luck!
Voeg je antwoord toe
Marco Mustapic zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,426
