Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
iPhone SE in bootloop after taking out battery.
I took the battery out of 2 of my iPhone SE’s to replace the powerbutton/volumebutton etc. everything did go nice and smooth as usually. But now they are BOTH in bootloop. I can’t think of any cause.. the only thing I can think of is that I bent the battery’s a bit, because both of the adhesive let loose :(. Could this be my cause? Because then i will just get some new battery’s.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
The battery will work fine, even when bent. Severe bands can cause fires, but gentle bends can be flattened out again.
Either your motherboard has a problem, or your power button is stuck. Try with the switch connections disconnected, and connect the phone (off) to your computer running iTunes. It should boot normally, I test motherboards out of case this way.
Was dit antwoord nuttig?
1 Opmerking:
It were big bends, anyways i dont think it is the mobo, and iT wont reset through iTunes. Both niet SE’s have the exact dame probleem..
door
Voeg je antwoord toe
Lars zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 54
