Ga door naar hoofdinhoud
Battery at 1%, searching for carrier and slow boot
Hi
A while ago I bought an iphone 7 (phone 1) that was used that had a broken screen. When I got it (phone 1) it wasn’t booting as it should, so I took out the battery and tried it in another iPhone 7 (phone 2). When I tried the battery in (phone 2), it (phone 2) wouldn’t boot normal either, and when it (phone 2) booted up the battery only says that it (phone 2) has 1% charge and when the lightning cable is plugged in it doesn’t say that it (phone 2) is charging. It isn’t recognized by iTunes neither. Also (phone 2) only stays at “searching“ on the top left corner (searching for carrier network). It (phone 2) is also really, really slow when in use. (Phone 2) worked as it should before I tested the battery from (phone 1). I have also confirmed that both of the batteries from (phone 1) and (phone 2) work as they should. (Phone 1) won’t recognize any audio device, so I suspect that it (phone 1) has a bad audio IC? But my question here is actually what is wrong with (phone 2) that worked before I tested the battery from (phone 1)? I am thinking that it might be the charging IC, but I am not sure.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Phone 1 definitely has the audio IC issue.
Phone 2 I would still try a new battery first. Then move onto the lighting port being a possible issue as well because of the searching issue.
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
I have tried a new battery in phone 2, but that didn't help. What has the lighting port to do with the searching problem?
door
The speakers work as they should in phone 1 also.
door
The lightning port has an antenna in it that connects to the logic board.
door
Try dialling *#06# on the searching phone. If nothing displays and/or IMEI and modem firmware is not present in phone settings general about the phone has a baseband circuit fault on the logic board.
door
Voeg je antwoord toe
Anders Tellefsen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 84
