Ga door naar hoofdinhoud
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Vragen Bekijk alle
Led #1 Blinking Blank screen, No chime
I just installed a new power supply, and the same blinking Led 1 shows up. No chimes, blank screen, Upgraded to High sierra with externalUSB 3 SSD. When i try to start the yosemite from the HDD internal. the system shutdown and never comeback to life.
Yes I plug back the External SSD but never start again no life signal. My keyboard and mouse are bluetooth wireless and try with wired keyboard and no light turn on. and no response.
SO what the blinking light would mean… so sad.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Straight from Apple:
LED Indicators
LED 1 - Indicates that the trickle voltage from the power supply has been detected by main logic board. This LED will turn ON when you connect the iMac to a working AC power source. The LED will remain ON as long as the computer is ON or asleep.
After disconnecting and reconnecting the AC power source, this LED could remain OFF if the AC power source is missing or disconnected, if the logic board is disconnected from the power supply or from the AC receptacle, or if the power supply board is faulty.
When computer has been correctly shutdown, LED 1 behavior may differ
If a startup event is scheduled in System Preferences/Energy saver, LED 1 will stay ON after a correct shutdown,
If no startup event is scheduled in System Preferences/Energy saver, LED 1 will turn OFF and will stay OFF as long as power cord is kept connected and AC power source is present. Disconnecting the power cord and plugging it back will turn back this LED ON, even if computer is still off.
LED 2 - Indicates that computer is turned on. This LED will be ON as long as computer is turned on (but is not asleep) and power supply and voltage regulators are working correctly.
LED 3 - Indicates that computer and graphic process unit (GPU) are communicating. This LED will be ON when computer is communicating properly with the GPU. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the backup battery (on back of logic board) may need to be reseated, or the logic board may require replacement.
LED 4 - Indicates that computer and LCD panel are communicating. This LED will be ON when computer is turned on and video signal is being generated. If LED 4 is ON and there is no image on display, then the LCD panel or the cables between LCD and logic board might be installed incorrectly, or need replacement.
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
Bad power supply and/or bad AC power!
It can also be a power surge or lightning strike damaged not only the power supply but the logic board as well.
door
I replace the power supply but the led still blinking no chime nothing else
door
Did you check your AC power?
As I stated a surge or lighting strike can also kill the logic board.
door
Thnk you Dan but nothing about blinking led #1 meaning , as i said even i replace the power supply
already
door
Then you have a bad logic board.
door
Voeg je antwoord toe
Samuel Mauricio Garcia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 124
