Ga door naar hoofdinhoud
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 Vragen Bekijk alle
cold replacement of the battery
My early 2013 MacBook pro 15” needs a battery replacement. The batteries are swollen. To make removing the battery pack safer, can this be done in cold conditions. I noticed that leaving the MBP outside for a day. The swelling decreased significantly. Will the adhesive remover work in temperature close to freezing?
Is dit een goede vraag?
1 Opmerking
I haven't tried to remove the battery yet. But one question. Would the dental floss method of cutting through the dissolved adhesive be safer?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Yep, it may take noticeably longer but will still work.
Was dit antwoord nuttig?
Good question! While the swelling will decrease as the battery gets colder, the effectiveness of the solvent will decrease as well.
So the trick is keeping the battery cold but allowing the aluminum uppercase to stay at room temp. Using a waterless Ice block you use to keep food cold should offer the cold to keep the battery under control as you allow the case to warm up.
The cold will also prevent the solvent to evaporate as quickly so you want to use less.
I would get a few sets of plastic cards to wedge underneath the battery cells as you free them up. You may need to re-cool your system and attack it again a few times. MacBook Pro 15" Retina-scherm begin 2013 Vervanging van de batterij
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery Afbeelding
Product
$79.99
Plastic Cards Afbeelding
Product
Plastic Cards
$2.99
Voeg je antwoord toe
Joe Pohlman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 137
