Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
0.2 inch Light stripe on the screen after dropping my phone
I dropped my phone, the screen didn't crack but I have this light on the side about 0.2 inch. Appended pictures.
Should I change a new screen or it’s a connection issue ? Anyone has any suggestion? thx!
Afbeelding
Afbeelding
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
Hey Piper, it is possible that the LCD connection is slightly loose, I would suggest disconnecting the battery, and then reseating the LCD connectors, and then connecting the battery. If this doesn’t work, it is possible the backlight in your display may have been slightly damaged, and will require a new screen to fix. I hope this helps!
Best of luck, Alec
Was dit antwoord nuttig?
Score 2
1 Opmerking:
The iPhone X has an OLED screen, not an LCD, and the lines seen here is typical OLED drop damage. A new screen s the way to go, unfortunately.
door
Super powaaaa, my mom has the same issue but she calls it her light saber!!!
Hi Piper,
Did you end up figuring out how to fix the light?
I dropped my phone and the screen didn't brake but now I have that same strip of light on the bottom of the screen. Hurts my eyes.
2 opmerkingen:
A friend dropped his iPhone and has the exact bright right edge. It must be a common thing and its fix.
Any info would be appreciated.
door
@emillach That's a damaged OLED; I've seen a lot of them. You'll have to replace the screen.
iPhone X Vervanging van het scherm
door
You can damage the LCD and not the Digitalizer, which is what looks like happened. a new screen should fix it.
I have a question my cell phone one day just stop working I cant get it to come back on.so I took it apart and theres a little brown mark on the strip that connects to the back of my screen what does that mean? If anyone could help me out with this that would be great thank u.
Voeg je antwoord toe
Piper zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 163
Altijd: 34,034
