Ga door naar hoofdinhoud
My tv won’t turn/power on after being unplugged for a couple of hours
I moved my tv and then moved it back to put it back on and plugged the tv back in, no lights or anything came on when I plugged in back in. I have changed the fuse in the plug, the power cable and the socket.
Is dit een goede vraag?
Score 1
2 opmerkingen
I had the same problem with our sony. later on we found out that it was a burned out screen bulb in the tv. We took ours for a tv trade in to get money off our new tv.
door
Hi @k12 ,
What is the model number of the TV?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hello,
If you had been check a all things means cable and power supply then you should talk to your customer service and talk to where you purchased it.
Was dit antwoord nuttig?
Score 1
get it checked from some professional technician or if your product is under warranty, take it to the service center maybe some internal problem is causing this issue.
Voeg je antwoord toe
Kier zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 858
