Ga door naar hoofdinhoud
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 Vragen Bekijk alle
To Fusion or Not - after transplanting my MacBook Air 512GB SSD
Hi,
After much toying around I finally transplanted successfully my old MacBook Air 2015 512GB SSD into my 27” iMac 2017. While at it I also decided to drop in a Crucial MX500 1TB.
Will a Fusion setup be faster than my old Mac 512GB SSD solo?
I take it a Fusion setup will probably not be as stable. But I backup regularly.
I’m very happy with the speed of the iMac post-transplant.
Thank you for any advice.
- Carl
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You don’t gain any benefit with a Fusion Drive setup with two SSD’s. In fact you loose performance! The best setup is a dual drive setup.
  • Use the blade SSD as your boot drive as well as hosting your Apps and nothing else!
  • Use your SATA drive as your data drive.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thank you Dan.
What would be the best way to proceed in terms of executing your suggestion?
Thanks again.
-Carl
door
Required steps:
● Backup your data!
How to split up a Fusion Drive
● Setup the blade SSD as your boot & app drive - Format & install OS - APFS
https://www.macworld.com/article/3284378...
◆ Leave the rest of the drive empty! Ideally 1/4 for a 512 GB/1 TB
● Setup the SATA drive as your data drive - Format - HFS+ if HDD, APFS if SSD
door
Hi Dan.
Big thanks.
I've done all that. Wish I could show you a screen shot.
I should have asked. How do I create Symbolic Links from "Macintosh HD" (which is the Apple blade to "Macintosh HD2" which is the storage drive.
I have something like 150GB in my Documents folder and another 100GB in Pictures which all really should be living on the HD2.
I thought a symbolic link would be the best way to do it?
I searched for creating symbolic links but strangely they weren't that helpful. I did get a good setup going using the following only to find problems with Downloading in Safari and Airdrop. So I gave up and thought I'd ask you. I suspect it's better to not remove the folder with the 'rm' command.
*All my data is still living on the portable external drives.
Admins-iMac:~ Carl$ pwd
/Users/Carl
Admins-iMac:~ Carl$ sudo rm -rf ./Downloads/
Password:
Admins-iMac:~ Carl$ ln -s /Volumes/HD2/Downloads Downloads
Admins-iMac:~ Carl$ ls -al
door
Simple put what are you trying to do? Give me an example or two.
Review this https://www.lifewire.com/aliases-symboli...
door
Voeg je antwoord toe
Carl zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 66
