Google play store :Unfortunately Google play store stopped
No caehe ! stopped 20! times all ready disabled 20 times! what else exeped reset?
Is dit een goede vraag?
Hi,
you can try soulutions from stack-exchange
Solution 1 – Update Google Play Services to the latest version. You can search for *.apk file. You may be getting an error because you have a very outdated version or the one you have is having a conflict/bug with the current Android version in your phone.
Solution 2 – Clear the Google Play Services cache. The Google Play Services app in your phone acts like a framework for all the Google and Google Play apps installed in your phone. You can try cleaning up its cache and see if that would fix the issue. This worked with one of our team members! Read these quick and easy steps :
Go to Settings > Apps.
Scroll to All apps and then scroll down to “Google Play Services” app.
Open the app details and tap on the “Force stop” button.
Then, tap on the “Clear cache” button.
Solution 3 – Clear the Google Services Framework cache. The Google Services Framework system app on your Android device stores information and helps your phone sync with Google servers — and keeps your Google Play Services up and running. This could be one of the reasons why you are not able to connect to Google servers using the app and keep getting the error message. Read these quick and easy steps :
Scroll to All apps and then scroll down to “Google Services Framework” app.
Solution 4 – Check your Internet connection. May be your WiFi network is blocking any of the IP addresses that Google use. You can also try switching the WiFi on or off on your phone — same with mobile data.
Solution 5 – This goes without saying, but may be a simple reboot of your Android phone/tablet could fix the problem.
Solution 6 – I hate to say this, but in the end, you might just want to install a custom ROM that is stable with no bugs.
If something helps, let us know.
Was dit antwoord nuttig?
I've factory and hard reset it twice , so I should clear the cache?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 24
Altijd: 2,595
7 opmerkingen
I will answer your questions if needed but need help pls
door Darkened wolves
make sure you have the most up to date version, if that does not help reset it I'm afraid.
door Dan
Well I fixed it with out reset!
Hi @darkened_wolves ,
Explaining how you did it may be helpful to others in the future.
door jayeff
Well the Google play services down gaded it self down dated it self and I needed to acesses it and update it and then undated it then it updates power down for me power up and it worked
2 commentaren meer tonen
