Ga door naar hoofdinhoud
The BlackBerry Priv is a slider smartphone developed by BlackBerry Limited. Following a series of leaks, it was officially announced by BlackBerry CEO John Chen on September 25, 2015, with pre-orders opening on October 23, 2015 for a release on November 6, 2015. It can run up to Android 6.0.1.
How to change the batery
the PRIV battery is drainaging  too fast. I want to change the battery
Update (02/11/2019)
the battery of my BB Priv is drainaging too fast after two years of usage . how to change the battery
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
(190) BlackBerry Priv Tear Down - Screen Repair, Battery Replacement - YouTube
Was dit antwoord nuttig?
Score 2
Me too. My Priv battery was only good for a few hours. There are a few YouTube videos on how to change the battery, just Google “Blackberry Priv Battery replacement” and you can get a 3rd party battery on Amazon for around $50. An original is about $150 and up.
You need to power down and remove the SIM and memory cards before trying to open the case.
It can be a bit tricky opening the case, that was my only problem. It feels like you will break it by pulling too hard, but it won’t break. I had to review the videos a few times to feel confident pulling the case apart.
You need a special screwdriver for 2 screws holding the connector down.
You also have to be very careful and very slow to pull the old battery off the glue holding it down. You don’t need glue to reassemble.
Reassembly takes a very few minutes. Just make sure the power and audio buttons are well in place first and that the cover clicks into place all around. Replace the SIM and memory cards then power up and recharge and you’re done.
Voeg je antwoord toe
JORGE MEDINA zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 2,366
