Ga door naar hoofdinhoud
Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327 Vragen Bekijk alle
Why is my keyboard not working?
Just woke up my laptop and my keyboard is not working at all, Touch Bar and Trackpad both work.
Have tried restarting and now can t even get into the computer as it won t let me past the password screen.
Nothing spilled on the keyboard, nothing touched it, it’s just stopped working!
Update (02/09/2019)
heres what diagnostics came up with
Is dit een goede vraag?
3 opmerkingen
Do you have a bluetooth keyboard or a USB keyboard and the needed dongle to plug it in? See if you can get your system to respond with one of them.
If you can run the onboard diagnostics by restarting your system press and hold the D key.
door
no issues found reference code adp000
door
Looks like you'll need a new uppercase.
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Take it in to Apple and see if they will fix it under the
Keyboard Service Program for MacBook and MacBook Pro
https://www.apple.com/support/keyboard-s...
Was dit antwoord nuttig?
Score 2
You either need a new uppercase or the logic board has a problem. either way this is an expensive repair $600 - 1200! See if you can get diagnostics to pop an error and post it here for us to see at least we can tell you which.
I would go to an authorized service center or Apple Store to get this fixed.
5 days and tried everything from resetting smc & pram or nvram and nothing worked. drained battery and let computer reset and nothing. today the battery drained, i plugged in the power, computer turned on and miraculously the keyboard now works…..any thoughts on this?
1 Opmerking:
Magic !! ;-}
I would still visit an Apple Store or authorized service center. Clearly you have something more going on here. Even if they don't find anything you want a record of the event.
door
Voeg je antwoord toe
michellekalogeraki zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 1,898
