Ga door naar hoofdinhoud
Epson's L220 is ideal for home and home office users looking for good-quality, ultra-low-cost printing, scanning, and copying. Released around 2016.
9 Vragen Bekijk alle
Why the ink is not flowing properly?
The printer functions all right but the ink, black yellow magenta and cyan, does not flow properly.
Is dit een goede vraag?
Score 3
1 Opmerking
Ink not flow correctly, i tried to clean the head but i dont know how to remove the head safly. other than the colours are not printed properly, how can i fixit the problem please.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
HI,
Based on evidences I found for this type it can be caused by:
  • Dirty ink inside your tank.
  • pipe leakage on tank side.
  • Head problem (factory defect, rarely happen but I found 1 case) which doesn’t have enough power to suck the ink from the thank.
Hope these simple explanation can help you to solve your problem.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
marga576 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,658
