Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
Gravity sensor isn’t working
Hello I bought my iphone 6s plus a month ago and I figured out that gravity sensor isn’t working. I can’t play games that contain gravity sensor and compass isn’t working too because of the sensor. What should I do
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hello sorry you are having this issue. Just be clear there is no gravity sensor on your iPhone. There is however an Accelerometer/Compass. This chip can fail from a bad fall. Since you only got your iPhone a month ago take it back and get a replacement.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
It might as well be a refurbished water damaged phone..ultrasonic machine is merciless with compass. The joys of buying from big online cheap refurbishers..they'll say the phone got dropped ;)
door
Yeah I know what you mean. It can be fixed though with a good local repair shop that does SMD soldering. Just FYI.
door
@iheartmacs Thanks for the info, good to know someone can actually do the job :D
door
If there is no gravity sensor, then how is turning the phone side ways accommodated with a turn to a long horizontal screen?
door
Voeg je antwoord toe
Rron Grezda zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 652
