Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Need to replace a component but can't find it nowhere...
In need to replace a component, saw filter, but don’t seem to find it anywhere on the net… Can you help me out?
This is the part:
FL2_RF FILTER_SAW_LMTPFJGAE 50_LGA radio_mlb(43C3)single_brd(24)
On the left side you see a piece of the battery connector.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I would suggest getting a donor board. I can't find any online either
Was dit antwoord nuttig?
Score 4
6 opmerkingen:
I’m somewhere ‘glad’ i’m not the only one who can’t find it :)
Donor board it is, thanks for the advice!
door
Donor board is a no go. The component false apart the moment you touch it... So if anyone finds a solution please let me know!
door
How did you try removing it. I tried on a board there and got it of without it breaking
door
Tried with hot air but the moment i try to pick it up with a tweezer it breaks. Thanks for your help!
door
try flux and 370c and dont grab tightly with the tweezers
door
1 commentaar meer tonen
These glass IC's are very delicate. It doesn't look like it has any underfill so you should let it flow properly before applying any pressure with the tweezers. Apply flux, heat it up and gently push it when you see adjacent components and solder start to flow. Once the IC's moves and bounces back, it's sign that it is ready to be removed.
Score 1
Voeg je antwoord toe
Bert Scheerens zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 74
