Ga door naar hoofdinhoud
Alles wat je nodig hebt om je iPhone zelf te repareren! iFixit biedt gratis reparatiehandleidingen en demontage-informatie voor elke telefoon, alsook de beste vervangende onderdelen en handigste tools.
36478 Vragen Bekijk alle
Difference In iPhone Battery Adhesive?
Is there any difference in the battery adhesive when it come to different iPhone models?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
different sizes for plus models, iPhone 8 has stronger type and in 4 smaller strips
Was dit antwoord nuttig?
2 opmerkingen:
Yes I understand but I was thinking more if for example an iPhone 6 battery adhesive can be used for an iPhone 7 battery. I found a place where I could buy 10 adhesives for a low price so I was wondering if it would work. They seem to be the same I dont know. Appreciate your response.
door
yes you will be fine buying any.
door
If you are doing more than one battery replacement get a roll of red double sided tape you can get this from eBay, same price as one battery adhesive strjp for an iPhone 6 battery for example.
1 Opmerking:
Yes I know. But I was wondering about the strips. They look the same for iPhone 6 and 7 for example. But thanks for the advice.
door
I would highly recommend buying the correct battery adhesive strips. If you just purchase any old double sided tape it will make it extremely difficult if you needed to replace the battery in the future. The strips designed for iPhones have ends that make it easy to remove.
https://www.ifixit.com/Search?query=ipho...
1 Opmerking:
I know. I prefer to use the strips than regular double sided tape. I just wanted too see if some adhesive are the same for some models. Appreciate the recommendation.
door
Voeg je antwoord toe
Bes Mak zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 508
