Ga door naar hoofdinhoud
Repair information for the Fitbit Ionic. A smart watch with GPS tracker and music player on bluetooth. This device has been recalled for safety reasons.
37 Vragen Bekijk alle
Replace screen Ionic - Ionic
I have an Ionic with a damaged screen and the replacement worked until last week firmware update… it is dead since then…
How could I replace the screen from the dead one to the broken screen but working ?
Is dit een goede vraag?
Score 2
1 Opmerking
I found this tutorial on youtube: https://www.youtube.com/watch?v=vZdALycI.... Would be great to see it on IFixit along with parts....
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Remove the strap from the wrist
heat the watch slowly to approx. 80 degrees Celsius
gently(!) place a opening tool between the glass and the frame of the watch and lift the glass carefully and slowly
disconnect the connectors
replace the glass
put everything together
WARNING: Be very carefull, since the rubber seal between the glass and frame is easily damaged and you need it to seal the watch. I haven't found any spare part for this yet and I did not managed to preserve it.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Hi! I also have a broken glass on the Ionic. Where can i find the repair guide and parts?
door
Voeg je antwoord toe
Jesus Fernandez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 2,929
