Doorzoek deze discussie om de juiste plek te vinden voor je opmerking. Klik vervolgens op "Link je opmerking aan dit bericht" om je opmerking te verplaatsen.
2 opmerkingen:
Hi,
Sounds as though there may be a problem with the clutch.
Have you checked the clutch fluid reservoir to see that the clutch fluid is at the correct level?
Try the following:
Apply the parking brake
Start the engine
Put the car in 5th gear and try to drive away
If the engine doesn’t stall, your clutch is faulty
Worn out clutch. blown U-joint or CV joint. Also, if you car uses a cable to operate the clutch. I had Plymouth minivan years ago with a manual transaxle that used a cable similar to a bicycle brake cable that also had an auto tensioner mechanism under the dash. The tensioner would over tension the cable to the point that it would cause the clutch to slip, wearing out the flywheel. Eventually I had to replace the clutch, flywheel and cable.
Hi,
Try the following:
Start the engine
door jayeff
Here are a few possible causes:
door niklaus37217
