Water Damaged Samsung Camera Flash Flashing After Isopropyl cleaning
Ok so I reccieved this phone as water damaged and when I dismantled it, I put the motherboard into a plate of isopropl alcohol and scrubbed it with a toothbrush and let it sit for some time. Soon, I let it all dry for a little and dried it with a hairdryer on the cold setting and when I put it back together, the camera flash keeps flickering on and off at varying intensities but there is nothing on the screen. This only happens when plugged in and not only on battery. However, with the camera flash flashing, there is nothing on screen. What else can I do?
Is dit een goede vraag?
Hi @jimmysofat6864 ,
Did you disconnect the camera modules and also any other flex cable connection and clean the cable ends as well with IPA when you placed the systemboard in IPA?
door jayeff
Yes, I disconnected all the flex cables and connections and cleaned them. Its worth noting that the led is soldered on the board and not able to be separated. I cleaned all flex cables and connectors.
door jimmysofat6864
