Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
20 Vragen Bekijk alle
Why is touch screen not working
I replaced the battery per instructions and now touch screen does not work. I hard restarted it, no good. I disconnected and reconnected cables multiple times - no good. I cleaned connectors with alcohol - no good. I tried to connect to iTunes but computer doesn’t recognize it. I am lost.
Is dit een goede vraag?
1 Opmerking
It is an iPhone 6S Plus
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hello,
Look at the strip link for the screen for the tears on the off chance that you left in appended while you pulled the battery, have Witnessed this various occasions when individuals cut corner pulling the battery.
It would be exceedingly far-fetched that board harm happened I would think changing a battery, except if you were simply too indiscreet.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Don Wells zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 77
