Ga door naar hoofdinhoud
Burnham steam boiler PIN4SNI-ME2, PSI valve replacement
I have the part, but is not sure how to uninstall old and install new. Do I simply unscrew it from the body of the furnace and install the replacement PSI valve. Anything I should be aware of (except, of course that the furnace needs to be off and cold when I do this)?
Many thanks, SE
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Here’s the service manual for your boiler Burnham Independence Boiler
Pressure valves are a very tricky thing. If not installed properly you can cause big issues!
I strongly recommend you get a trained heating technician in to install it for now. If you really want to learn go to a good vocational school to study heating.
Just the other day a home near here blew up! The homeowner tried fixing his boiler and now he’s homeless!
Was dit antwoord nuttig?
Voeg je antwoord toe
sam engelstad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 196
