Ga door naar hoofdinhoud
Is there any way to open my power adapter?
My Asus g73sw charger adaptor I bought seems in very new condition but as I plug in to the wall the light on the box doesn't turn on. That's why I'm wondering how do you open this type of charger? Just want to see if any capacitors aren't burnt or leaking since that can be causing the problem?
The 2nd picture I believed I some type of screw but not sure if I can removed them since it looks it has a pin in the middle of the screw.
Is dit een goede vraag?
2 opmerkingen
Hi @fernando21 ,
If it is new and there is no output when tested by a Voltmeter, contact the seller about a warranty replacement.
Do not void the warranty by trying to open it.
door
@jayeff I practically got this charger adaptor for free better than the old one I have since looks new from the outside but most likely has an issue in the inside. Last time I use a multimeteter on it I didn't get the voltage that it was suppose to come out.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I found out how to open it up you need a special type of screw adaptor tip. I opened it up inside it looked very damaged even the board was cracked. I think someone try to fix it but couldnt done it.
No voltage with multimeter
Thanks for replys guys.
Was dit antwoord nuttig?
1 Opmerking:
Het nuttigste antwoord
Hi @fernando21
I would suggest checking the power adapter first using the multimeter to confirm for any DC output voltages.
What kind of adapter were you provided with? the square one or rectangle one?
Score 2
1 Opmerking:
@salmonjapan I updated the post with pictures and I believed I might need special screw driver to remove these screws . Yes it sqaure power adapter. Thanks for responding as well.
door
Voeg je antwoord toe
Fernando zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 128
