Ga door naar hoofdinhoud
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
20 Vragen Bekijk alle
Vraag afgerond
Did I order the wrong battery?
I have a clickwheel which I thought was called 4th generation by you guys. The photo on the battery package looks exactly like my iPod. When I went to get the installation instructions online the battery pictured was white. The one in my package is black. Lil' help? :)
debra
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The color of the battery doesn't matter.
What matters is if the battery is compatible.
Is it the same shape size as the other battery being replaced?
If so, than more than likely it's the right battery!
If it's smaller, but has the same connection port it's probably a 3rd generation battery. Funny enough, that will "also" work with your 4th generation. I'm not sure if it provides less playing time, but it probably does. Never the less, they both still power the devices for hours.
Good luck! Make sure it fits ok and don't force the case together if it's not wanting to snap back together. I've seen one replacement battery for a 4th generation not fit and it's pretty rare, but still, make sure it fits!
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 826
