Ga door naar hoofdinhoud
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
20 Vragen Bekijk alle
How to get my data from hdd?
Hello,
I have MacBook Pro 2011 and after the logic board problem I can't log to my MBP ! I have very important data on it!
Now I have a PC with windows 10 how I can get my data again ?
Note: The MBP had a password when it's work properly.
Is dit een goede vraag?
4 opmerkingen
This just make internal hard disk as external hdd I have tool like this.
The problem is: I can't see my files in hdd Because the OS is different.
Thank you for answer.
door
Hi @aligraphics ,
There's info online that shows how to read mac files using Windows. ;-)
door
Thank you so much, I made it before this but I can't see my data only system files exist!
door
Hi @aligraphics .
You can try this and see if it works. It says that there is a free 5 day trial before you have to buy it ;-)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Buy the enclosure here and transfer your MacBook Pros hard drive into the enclosure. Plug the enclosure into your new computer and you can retrieve the files thru there.
https://www.amazon.com/AmazonBasics-2-5-...
Was dit antwoord nuttig?
Voeg je antwoord toe
Ali zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 71
