Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor de OnePlus 5T, een Android-smartphone met een 6,01" AMOLED-digitaal scherm. Uitgebracht in november 2017. Opvolger van de OnePlus 5. Modelnummer: A5010.
Issues with screen after replacing
Hello,
I'm experiencing some issues after replacing my screen. I'm getting a lot of ghost touches when scrolling, and every few days the screen goes crazy with clicks. Completely unusable. Can't do anything but hard reboot which fixes it. The Keyboard is a bit off. Most gestures work, but only if you use a different one each time. Example: You can't use 'V' twice in a row. You have to do a different gesture each time or it won't respond. Music gestures don't work at all.
Everything else works as it should.
Any idea what could be causing it?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Probably needs the digitizer cable reset. OnePlus 5T Demontage here is the tear down video if you feel like doing it yourself. The LCD able is around 3:43. If that doesn’t do it it is probably an issue with the motherboard connector or the LCD connector itself. My guess would be that it is not seated properly.
Was dit antwoord nuttig?
Original screen folder Amoled
Voeg je antwoord toe
Liam Mooney zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 1,993
