Ga door naar hoofdinhoud
De Asus N76VZ, uitgebracht in 2012, is een 17-inch laptop met een schermresolutie van 1600x900 pixels of 1920x1080 pixels. Het bevat een 3e generatie Intel Core i7-processor en een grafische kaart van Nvidia.
Why can't remove battery
Hello
I am trying to remove battery on Notebook Asus N76V, but I think it have problem with the slider lock because he is on the wrong position and now it is very hard to remove it, I tried a little force to remove it but I wasn’t able to do it… I searched many solution but I didn’t found the solution.
Edit: it is Asus N76VJ but I think it’s the same way to remove battery.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
It’s likely that the slider to unlock the battery is broken. First try sliding it to the unlocked position and force the battery out. There isn’t much you can do other than replacing the bottom case. I’ve found though that a lot of times if I force it out, it will come out with little damage.
Was dit antwoord nuttig?
Score 3
with flat head screwdriver,
start to lift battery pack from back ( furthest away from battery open slider )
start to lever from right or left ,,, lever from either corner
This worked for me and i did no damage to mechanism
operate lever and apply some silicon spray
Score 1
1 Opmerking:
This was actually helpful!
I used a plastic pick and started wiggling and sliding.
I spent more than 30 minutes trying before seeing this tip, and I was so happy that I didn't break anything lol
Thanks
door
Voeg je antwoord toe
Mickael Gomes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 1,421
