Ga door naar hoofdinhoud
Released on July 28th, 2017, The New Nintendo 2DS XL is a technologically-improved remodel of the 2DS handheld. It is the ninth and last redesign of the Nintendo DS line, The console is much larger than the original 2DS model and adds all the features of the updated 'New 3DS' line of systems, minus the ability to play games in 3D on the top screen.
My device doesn't start...
I’ve repaired the Nintendo 2ds xl top screen, because it was damaged.
Now if i want to turn on my device, the blue light turns on for about 4 seconds, both of the displays are flashing and then the blue light and both of the screens turns off :(
What can be the reason?
I’ve thought it can be the battery, changed it and the same issue is happening..
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
Check the ribbon cable connection of the displays. If those are not seated properly or if the cables themselves are a bit damaged (scuffed or dented), the console won't turn on.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
But if the ribbon cable connection of the displays are not seated proberly, will both displays flash up then?
door
Hi!
Yes, a bad connection does not mean that there isn't any connection, it just means that it's not enough to get a good enough signal trough.
It's honestly a dumb feature implemented by Nintendo to have the consoles check the hardware upon boot and shutdown if anything is wrong.
door
can it also be a broken mainboard?
A shot smd or similar?
Or is it a pretty clear sign of no good connection?
door
To me it's a pretty clear sign of a bad connection. The chances that you broke the main board while replacing the display are quite low.
door
Voeg je antwoord toe
Michael D zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 444
