Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
My phone has been on 1% for three hours now on the charger
my phone was at 19% and then suddenly jumped to 1% and shut down, I can't turn it on at all (even tried to hard reset and it didn't work) so i put it on the charger and now it's stuck at 1%. it's been charging for three hours.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Either the battery died or something went bad with charging circuit. Unless you have a multimeter to test battery voltage and connector on the iphone board you may try to replace the battery and hope for the best.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
One thing all mobile phone owners should have is a USB Ammeter. You can check your charger, cable for voltage and current draw. They cost about $15. My meter has saved 5-6 people from phone repair when phone was fine but cable/chargers were bad. Edit: iFixit has meter for sale: $9.99!
USB Mini Voltmeter
door
That is the problem of SWI line, Bad Contact of the battery and battery connector cause that issues.
Battery have 3 pin to connection.
1 +VE
2 -VE
3- SWI- the center of the battery connector.
You can also check by the 3Utool the status like below on the image.
First image shows the Detail of the battery means SWI is connected stage.
Second image shows the BSI not connected or faulty or bad contact.
By this way you can find out the proper solution.
Score 1
Voeg je antwoord toe
Lilith Yandow zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 671
