Ga door naar hoofdinhoud
At the 2004 North American International Auto Show, Nissan unveiled a completely redesigned Pathfinder for the 2005 model year.
14 Vragen Bekijk alle
Why my 2012 Nissan Pathfinder loses brakes completely on the road?
Hit a pothole 8 months ago and lost use of brakes entirely for a few minutes, Eventually brakes recovered after continuous pumping of brake pedal. Since then it has done it several times while driving without even hitting potholes or any uneven surface on the road. Have serviced four wheels and replaced Master Cylinder and it still happens.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I would have a mechanic check your break lines, and maybe a search to see if there is some sort of sensor for your ABS
Was dit antwoord nuttig?
1 Opmerking:
There are four sensors, one on each wheel. Then there is the ECU which controls the ABS breaking process. Nissan Dealer has checked all of that but has revealed nothing out of the ordinary. When this problem happens not even the brake malfunction light on the dashboard lights up…. Poltergeist?
door
Voeg je antwoord toe
Julio Lynch-Lorca zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 329
