Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
How to flash firmware on ipad?
The ipad is stuck at recovery mode whenever i try to recover with itunes- progress bar does not move. It has been suggested a firmware flash is needed, but the software I have seen requires payment. Are there free software to flash firmware? Or am i using the right method?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You are using the right method. I suggest trying to re-install iTunes first if that does not help then try 3UTools with the repair driver method shown in the program.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Patrick Lam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 2,156
