Ga door naar hoofdinhoud
MacBook Late 2006 boots to white screen, but works on external monitor
I recently swapped the display in my Macbook Late 2006. It was cracked and I found a cheap working display on eBay . The Macbook boots okay but the display remains white. I connected an external monitor and the Macbook works fine with that.
Do you think it’s a faulty display?
Or is it possible I have connected the display cables incorrectly?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sounds like you got the wrong display assembly. While they look the same they are not the same!
MacBook 13.3" Core 2 Duo Display Assembly Afbeelding
Product
$299.99
MacBook 13.3" Santa Rosa/Penryn Display Assembly Afbeelding
Product
$299.99
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Ok thanks. I’ll have a look.
Is there a way to check the display part number from System Profiler or using an app?
door
Plug in your systems S/N into here EveryMac - Lookup it will tell you the exact model you have as they both look the same.
Basically, the Intel graphics services (Intel GMA X3100 & Intel GMA X3100) is what defines which display is needed. As the signaling is different enough that each needs a unique display assembly.
door
Voeg je antwoord toe
Matt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 54
