Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
iPhone 6s plus Backlight pins
HI, I am trying to repair a LCD that got issues with the back-light does anyone know what the 7 pins on the back light and LCD are as I am really unsure i have tried to also check at board schematic to try to trace back which pin is which but no luck.
Any help would be appreciated.
BTW I am 15 so if I am doing something wrong here please do correct me :)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I haven’t probed this directly but the seven pins are probably the 6 Anode/Cathode pins in the diagram below and Ground.
You can probe these pins for continuity with the larger connector by following this pinout:
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Thank You exactly what i needed
door
Another question can someone tell me the exact pinout of were these pins are on ther acutal backlight pannel
door
Voeg je antwoord toe
Obsidian Force zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 423
