It does sound like an airlock, I managed to sort my machine, with the same problem, by doing the following:
Phase 1: fill water tank and with machine turned OFF and everything set to dispense cold repeatedly put the water tank on and off. This pushed water into the system, you can check it is working by looking for air Bubblé rising in the water tank as you do it.
After approx 40 cycles (probably equivalent to 1 mug of water) or if water starts “leaking" out the back of the machine clean up any residue/spilled water.
Phase 2: *please ensure all spilled water is cleaned up so the unit and area is dry!
Refil water tank, put into correct position and turn machine on, with capsule holder and lever in dispense position. Waitt until green light shows then switch lever to hot water position. CAREFULLY lift and replace water tank “pushing more water” until it dispenses water by itself.
Use the rest of the water in the tank to flush through. I cycled between hot and cold.
Phase 3: celebrate!
4 opmerkingen
Hi does anyone have any idea why my Nescafé dolce gusto Krups has no power has anyone has this problem
door debbiecork
My dolce gusto drop is not pumping water i can not hear the pump at all
door Kian moolraj
Hooray! It took about 40 goes to pull out and replace the water tank but eventually the water started drawing. Thank you for sharing your experience, I was about to send it back!
door elisabeth
I had the same problem with my dolce gusto drop machine. Brand new but stored for more than 5 years. Water will not flow. I moved the water tank in and out for more than 1000 times. And also used a squirt bottle to squirt water into the water inlet. I was going to give up. The service centre guy told me I should probably throw the machine away as they don’t have spare parts for this model anymore. But I didn’t give up trying ( motivated by many people in this post), and prayed really hard too. And finally it worked!! Water started coming out. It was a little dirty with some debris looking dirt. I am soooooo happy I found this post. You all really helped me a lot!!!! I am grateful and thankful that I don’t have to throw my “new” machine away. Thank you all!!! I love my coffee ☕️
door Alien 👽👾🛸
