Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Vragen Bekijk alle
Replaced battery and now only shows Apple logo
I just replaced the battery on my iPhone 3G.
When I plug it into the wall charger it shows the apple logo then turns off. If I hold the on button it does the same. If I hold on and home for a while it shows connect to iTunes. Upon unplugging from the wall to connect to the computer it turns off.
It will not do anything if not connected to the wall. Even if connected to the computer.
Dodgy battery?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Here's what you do. Connect it to the computer. Turn it on, and press the Home button while pressing the power button. Then, let go of the home button. It should say Connect to iTunes. Then, open up iTunes and select Restore. It will delete everything, so make sure you have everything updated on your computer. Let it download and install the software. Then try it out.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
your battery is bad.
Score 2
First - Is the new battery charged?
Second - If it is charged then follow "Hello's" Advice.
Voeg je antwoord toe
mpassman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 2,119
