Ga door naar hoofdinhoud
Repair and troubleshooting guides for the Acer Aspire V3-571G-9686. This 15.6 inch laptop was released in October of 2012.
Green line in right side of the display.
Hello. I own an Acer Aspire V5-571G laptop, with IPS LED Display, 1080p resolution. Suddenly, a vertical line has appeared in the right side. It changes the color, on white is green, but on black it is not visible. Do i need to replace the display or maybe is just the connector?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi Răzvan Alexandru
well, test with an external monitor /display to confirm the lines is on your laptop display.
you can try reaseating the LVDS cable and see if it helps.
what you are seeing line … most probably the lcd display bonding on your laptop display is not well bonded.
you can try stripping till you see the lcd module, and try applying light pressure to it.
sharing a video, fyi.
https://www.youtube.com/watch?v=UNf81Z-i...
imo the video is a short temp fix.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Răzvan Alexandru zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 285
