Ga door naar hoofdinhoud
The Hover-1 Liberty is a self balancing e-scooter or hoverboard. It has a max speed of 7.4 mph, a max weight capacity of 160lbs, and it can travel 3 miles on a full charge. It also comes with LED wheels and Bluetooth capabilities. Model: HY-LBTY.
Wheel does not seem to be straight
The one wheel on my daughters hover board is not straight and moves quite a bit compared to the other.
When I opened it up there were little black bits ??? Compared to the other side it looks like a plastic clip is missing?
Is there a way to staibilize the wheel? Hover 1 won’t help us due to the receipt is not with us as it was a gift …
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I’d first check the bearing. Use a magnet to tell if the bits are metal or plastic.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
all bits are plastic and wheel goes down at last i used only 2 times
door
Voeg je antwoord toe
Les hill zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 384
