Ga door naar hoofdinhoud
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
256 Vragen Bekijk alle
Phone keeps vibrating and won't turn on
Hello
My phone switched itself off and is now vibrating twice and keeps flashing the samsung sign.
I downloaded an app off Playstore yesterday and everything seemed okay. But now it is not working properly.
I tried to do a reset but it is still not working.
Help please
Is dit een goede vraag?
Score 2
2 opmerkingen
HPhone keeps vibrating and won't turn on
door
My samsung j1ace suddenly tripped off. When I tried turning on it started vibrating and the screen was blank. Pls what can I do?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
May I know the app you downloaded?
This ‘app’ may of downloaded malware to your device and caused the phone to keep shutting itself off.
Otherwise, try the following steps;
Step 1. Open the back cover of your Note 4, remove the battery and wait a couple seconds, then insert it again.
Step 2. Hold the volume up key, power button and the home button simultaneously. When the ‘Recovery Booting…’ text, release these buttons.
Step 3. Select the cache option and press reboot. If this doesn’t work, repeat Step 2, press the cache option, and select format device. (Note! Formatting your device will wipe your device clear of all files.)
Hope this helped!
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Hi I downloaded Wordscape.
I have tried step 1 and step 2.
I have attempted to try step 3 and it said Recovery Booting, I released the buttons and it said installing system update and keeps restarting again.
door
Oh ok, instead of me explaining it and getting you to understand, please watch this helpful video on YouTube: https://www.youtube.com/watch?v=KCocwC50....
Edit: Also, try just letting it keep restarting when it's installing system update, after a preset amount of time it will stop restarting and give you the normal recovery options.
Hope this helps.
door
Thankyou. I will have a look at this video :D Hopefully, it will help.
door
Voeg je antwoord toe
alishasamms305 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 40
Altijd: 8,861
