Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
WiFi still greyed out after replacement
Hi all, I have an iPhone 5s and it’s WiFi and Bluetooth hasn’t been working for the past 3 years or so and I finally Got around to buying the tools and a new WiFi/BT antenna. After replacing the antenna following the guide on ifixit neither of them worked but I took another look at it and I’m not sure what I did but I got the Bluetooth working (before it was spinning) The WiFi still is greyed out and I would really like to know why, please can someone help me?
Is dit een goede vraag?
2 opmerkingen
is it grayed out or just no signal.
door
Sorry, I should’ve clarified... it is greyed out, the WiFi is not turning on and after replacing the adapter the Bluetooth is now functioning whereas before it was a spinning circle
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
A grayed out wifi usually means the IC is not recognized by the system and it’s a logic board issue you cannot unfortunately fix without troubleshooting at component level. I’d recommend not to invest further time and money in components; also a repair would not be very advisable given the current iPhone 5s value
Was dit antwoord nuttig?
Score 1
You have to replace WI-FI chip that fault from (WI-FI module).So you have to change complete module coz Bluetooth and WI-FI both are invealed on that
Voeg je antwoord toe
Peter Schreiber zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 144
