Ga door naar hoofdinhoud
The HP 15-r137wm TouchSmart contains the fourth generation Intel Core i3 processor with a 15.6" LED-backlit high-definition touchscreen display. It contains 6GB of RAM with a 750GB hard drive. The HP 15-r137wm TouchSmart comes complete with Windows 8. The HP 15-r137wm TouchSmart model number is 15-r137wm, which can be located on the bottom of the laptop in the far right corner under the battery.
5 Vragen Bekijk alle
Keyboard Zif separated from MB
I have accidentally separated the keyboard Zif connector on my HP 15-n230sa laptop from the main board. Didn't realise the tab was on the opposite side of the connector and stupidly prised it off the board.
Please would you mind taking a look at the pictures and tell me whether this can be rectified? Is there anyway to reseat it back on the board?
Thanks in advance!
Is dit een goede vraag?
1 Opmerking
I will find some who can re-solder this for me. Thank you very much for answering my question, much appreciated.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You are very lucky! The solder pads didn’t get damaged so it should be possible to re-solder the connector back down.
Now the tricky part! To do this right you need a re-work system which uses hot air. Your best bet is to find someone local to you with the needed tools to remount it.
Was dit antwoord nuttig?
Score 1
go to hit shows on utube, the fellow speaks mostly indian, but if you watch he cuts plastic to fit over the end of the ribbon and a small piece for tension on the underside and heats them and then inserts them and they hold solid.
Voeg je antwoord toe
Andrew Hawker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 149
