Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Vragen Bekijk alle
iPhone screen going rainbow coloured?
Just carried out a screen repair on an iPhone 7 Plus.
Sometimes when waking it up, the screen will be of a largely rainbow tint on the left side. Touching the screen or moving it around solves the issue.
Anyone have any idea what this could be?
I have attached a picture of the phone prior to the repair and a video of the rainbow.
Thanks in advance.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Is there any spongy feeling when you lightly press down on the screen on the bottom right corner? If not return the part and get a replacement screen. Could be a bad LCD or you screens IC is being pinched between the bottom of the logic board and loud speaker.
Was dit antwoord nuttig?
4 opmerkingen:
@toreskey Nope, no spongy feeling. The only reason I didn’t know it if was to do with a faulty LCD is because it’s only sometimes. Usually when I see faulty ones, they’d be a line down it, or an area of the digitiser doesn’t work. Didn’t know if something that only occurred on some occasions was to do with a faulty part.
door
@toreskey Because literally, I’ve just had it again. Scrolling up and down on the screen fixes it. Also, it flashed like a faulty digitiser does when it moves itself up and down. But after doing that, it goes back to normal
door
I would see if you can get a replacement screen then. If you did the process properly, It's most likely a faulty screen.
door
@toreskey Okay, I’ve got plenty. Thanks for your help.
door
Voeg je antwoord toe
Sam Mileberg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 2,058
