Ga door naar hoofdinhoud
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
151 Vragen Bekijk alle
iPad 6 screw set.. help!
Purchased an iPad 6 in a partial state of repair, and it’s missing the four #00 4.3mm screws holding down the LCD, one #000 2.3mm for the battery connector, and three #000 1.4mm screws for the display bracket. I have been searching for hours online for a screw set and I totally can’t find it for the 6 or 5, and earlier models don’t have the right screws. Does anyone know where I could source a set or find more specific dimensions for these screws (thread length/width)? Much appreciated.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Don’t look on google for “iPad 6 screws, instead figure out the screw type you need and look those up. That is significantly easier to find. The screw set that @sammyzhang commented earlier should work.
Was dit antwoord nuttig?
Score 2
Did you get a set? I can’t find any.
I’m still looking myself. It is amazing how no one sells these atm
2 opmerkingen:
I finally found that they can be ordered through Genius Phone Repair. $1.24
door
Voeg je antwoord toe
Evan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 29
Altijd: 1,608
