Ga door naar hoofdinhoud
Cracked Case?
Near the thumb-scoop there appears to be a small crack running parallel to the case (follows the curve of the scoop) and is about the length of the trackpad button. It is only small but is there something I can do without replacing the entire case?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
You have to show it to your local Apple Service Provider. I some cases Apple will repair the MacBook.
- shurai
Was dit antwoord nuttig?
Score 2
1 Opmerking:
It's not under warranty though
door
I see, so the top case actually has a crack in it. For a complete fix you will need to replace this. You can use this guide to carry it out.
Score 2
2 opmerkingen:
I'd rather not pay $169 USD and just keep it as it is. It doesn't bother me so i will just leave it
door
I agree, maybe you could try shurai's suggestion?
door
If the crack is on the keyboard then they'll repair it at no cost. They said it is recognized as a design flaw. However if the crack is anywhere else then you'll have to pay for it
I have the same problem with my black macbook, I use black electrical tape to cover it, it's the perfect color, if you have a white macbook you could use white electrical tape.
Voeg je antwoord toe
AussieMac zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,721
