Ga door naar hoofdinhoud
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Vragen Bekijk alle
Need one replacement (short) screw for bottom cover?
After upgrading RAM, I was replacing the bottom cover, and one of the short screws went flying. Can you tell me the size, and ideally a source?
I see that iFixit has full screw kits, but they are $60 and out of stock besides.
Thanks,
Tom.
MacBook Pro 15" Unibody (Mid 2010 - Mid 2012) Screw Set Afbeelding
Product
$49.99
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I may be wrong but suspect it is a 3mm long Phillips screw and expect it's the same thread size as the longer (13mm) screws.
The screws appear to be a M2 thread with a #00 Philips head
EDIT
A quick search of eBay with "macbook screw A1286" shows a few kits for around $20.
HIH
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Richdave: this was very helpful, thanks! I'm pretty sure you are right about the size. I ordered some 3.5mm screws and will provide an update once they arrive.
Thanks again!
door
How did you make out?
door
My long-overdue update: the screws I ordered worked fine.
door
Voeg je antwoord toe
Tom Smith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 3,242
