Ga door naar hoofdinhoud
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
Home Button Flex snapped
Hi,
I was replacing the screen on my iPhone 8Plus and the flex for the home button snapped. The flex in question is the one that runs along the metal shield, not from the home button itself. Is this replaceable and if so, where can I get one from?
Cheers
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If the flex in question is the one that runs underneath the heat shield and connects to the logic board (see Step 44 of this Guide), then the only way to replace it is to replace the entire screen assembly. The little nub that connects to the Home Button Flex goes underneath the backlight and connects with the rest of the flex assembly which connects to the board. That flex cannot be replaced.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
I was fearful this was the case. I couldn't find any information on the internet that pointed to this but I guess I'll fork out for another screen. That will teach me for being so clumsy. Thank you!
door
I connected mine together using some solder and tape, it works.
Voeg je antwoord toe
Joel Innard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 390
