Ga door naar hoofdinhoud
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
Lagging iPod 5th Generation
Hey guys,
My iPod 5th Generation lags when I play certain songs. I’ve tried already a lot of possiblities: first deleting only this album, uploading it again, but the same. Then restoring the iPod through iTunes, then I upload again three albums and already at the 5th song starts to lag.
At this point I can feel while holding in my hand that the hard drive is lagging too. I can escape of this only with the two button reset. After that everything is fine again till I get to one song where it starts to lag again.
How could I solve this problem? Do I need to change the hard drive, or there is other possibilities?
Is dit een goede vraag?
2 opmerkingen
which iPod 5 is this? sounds like the original...
door
iPod 5th G. 60gb Serial No : 8K632DWKWEF
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I think you are correct that it is the HDD, the iPod is several years old and has likely played a fair few tunes in its time. You will need to find a new HDD and follow this guide
iPod 5th Generation (Video) Hard Drive Replacement
read the guide a few times, take your time and it should be fine.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Mine went a few years ago ended up putting in a SSD unit Tarkan iFlash-Dual SD Card Adapter For iPod 5 Generation and Later best upgrade I could have done!
door
Voeg je antwoord toe
Tamas David zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 670
