Ga door naar hoofdinhoud
Samsung's flagship phone-with-stylus and the successor to the Note8, released August 2018. Features a 6.4" display and up to 512 GB of onboard storage.
94 Vragen Bekijk alle
note 9 sim pick into the mic hole
Hello, a similar situation to the one described here : Microphone could be damaged? but with the samsung note 9.
A sim pick tool was introduced into the microphone hole by mistake. Consequences? On the mic? On the waterproofness?
Is the physical arrangement the same as for s7 edge (in the example above) ?
Thank you.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
As long as you didn’t go too far the mic should be fine, but the IP rating would technically probably drop.
Was dit antwoord nuttig?
3 opmerkingen:
Thanks for your answer! How exactly could I test the mic? Since it's not the one used in conversation... More, I have left the phone for 20 min under 10cm of water. No problem.
door
If it isn't the one used in convo, you should be able to test it by recording a video
door
use samsung voice recorder in interview mode.
door
I poked both the mic and another hole near the sim slot by mistake. All seems to be wrong. Could there be any damage to the one near the sim slot. And what is it for. Can I help?
1 Opmerking:
Working* not wrong :)
door
I have heard that no harm will come to the mic. Worst case you have pushed into the rubber seal.
Voeg je antwoord toe
No Azerty zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 2,800
