Ga door naar hoofdinhoud
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Vragen Bekijk alle
Why is the new replacement battery not charging?
I ordered a replacement battery from iFixit and installed it. Unfortunately, the battery is not charging and my laptop can only remain on by staying plugged to the power cord. I reinstalled the old swollen battery and holds a charge for about 40 minutes before shutting down. Also, the light on the charger is green at all times when the new battery is installed and the old battery goes from green to orange to green once charged.
Is this a sign of the new battery being defected? I’ve done a NVRAM/PRAM and SMC reset with the new battery.
Thanks
Update (12/10/2018)
Attached are pics of the results.
Is dit een goede vraag?
Score 1
1 Opmerking
How was the old battery unplugged the first time? Was it with a metal pry tool by any chance?
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
As per your statics may be the ordered battery may have some issues and these issues can be treated directly by demanding a replacement battery from ifixit, if after doing NVRAM/PRAM and SMC reset with the new battery is not able to solve the issue and may be an issue with logic board
Was dit antwoord nuttig?
2 opmerkingen:
You don't have to demand anything, just ask.
door
@mayer Ok just ask for a replacement battery
door
Hi Daniel,
What ended up happening? I JUST installed a new battery on a mid-2014 MBP from iFixit and I’m having the same problem!
3rd party battery often draws more current then orignal one. I've tackled same issue on one laptop i received for repair. i checked entrie charging circuit on logic board but i didn't find issue….then i took cells from new battery and attached to original battery pcb and bammm it's done
Voeg je antwoord toe
Daniel Venegas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 286
