Ga door naar hoofdinhoud
Repair guides and support for Apple webcams.
8 Vragen Bekijk alle
External iSight on MBP Early 2015 via Thunderbolt-Firewire adapter?
I want to connect external Apple iSight cammera to my MBP (early 2015) via Apple Thunderbolt-Firewire adapter. Has anyone successfully tried this?
I guess it’s supposed to work, but I’d like to check before buying the adapter. I read in some cases the adapter doesn’t recognise the camera.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I’ve got one hooked up to my 2008 Mac Pro using a Firewire 400 to 800 but have not tried it using Thunderbolt to firewire adapter. I have a MBP 2016 running Mojave and the Firewire 800 to USB C adapter and the 400 to 800 adapter. So later today I will give it a try unless you get a definitive answer.
Mind if I ask what software you are going to use and to what purpose? I have three iSight cameras and would like to set up a security system to utilize them ;-)
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
@mayer Thank you for your answer.
I mostly use my MBP 2015 in clamshell more. So I need external camera for video chat. I have a spare iSight and wanted to utilse it. But I read that this combo (iSight - 400-800 firewire cable - firewire-Thuderbold - Mac) doesn’t always work.
If you can try it, I’ll be very greateful. :)
door
Poke me during the daytime and remind me, as I not only answer questions but run a business.
door
It works on a Mac Mini. I’ve tested with FaceTime and MS teams.
Score 1
1 Opmerking:
What year model?
door
Voeg je antwoord toe
Blaž zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 763
