Ga door naar hoofdinhoud
The Black and Decker Dustbuster CHV1410 is a cordless hand vacuum used for light household cleaning. It is also a member of the CHV model series.
Can I change my dust buster battery and if so where do I get it?
Black and Decker dust buster CHV1410L built in rechargeable battery has died. Can I purchase a new battery? If so where?
Is dit een goede vraag?
Score 2
1 Opmerking
I have successfully replaced the Lithium Ion cells in three CHV1410L units. Tenergy 2.6AH 18650 cells are available under their part number MH48285 (with the tab option). Replacing the cells is fairly straightforward, the only issue is alignment of the cells to allow connection between the cells and to the battery control PCBA. Work on a non-conductive surface and lay out the cells before you start to wire them together. Keep tools and metallic objects away from the work area for safety. {I'm pretty sure I took pictures one time, which I will try to locate and add to this article.}
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
The wiring looks to be fixed to the board which is fixed to the battery pack. Can't replace the battery so the whole thing is trash. On the *inside* of the product is a sticker that includes a reminder to recycle your (as you just discovered) irreplaceable lithium ion battery. Insult to friggin injury.
Was dit antwoord nuttig?
1 Opmerking:
Replacing a dirtbuster battery is a total joke…Just have to replace the whole unit…Black & Decker shore did a crappy job on battery replacement when
they designed it !!!!
door
Het nuttigste antwoord
https://www.youtube.com/watch?v=1N7R9nRO...
The guy also has a link to buy the replacement battery on amazon in the video discription.
hope that can help.
Score 1
3 opmerkingen:
The link in the video description is currently (Aug 2023) pointing to an Amazon listing for the full vacuum, not the battery. Guessing it was changed? No longer useful. :-(
door
Did you get any link to buy the battery and the BMS?
door
You can search for CHV1410L battery on ebay. They come from China priced at $35. It requires soldering so not an easy job. Currently you can get the same vacuum on ebay or Amazon for $39 so it's not worth it anymore. Just get a new one.
door
Of course the batteries are replaceable. If you are handy with small tools and a soldering iron or mini spot welder. The pack, depending on model, consists of 4 or 5, 18650 lithium ion cells. If you can, buy then with solder tabs already attached. That makes the installation much easier. Otherwise you will have to solder directly to the battery cells or use a small tack welder available on Amazon, Temu or eBay. Be careful working with these cells as they pack a lot of energy in a small package and accidentally shorting them could lead to fire or explosion. If you are handy with tools and careful, the batteries are definitely replaceable.
Score 1
2 opmerkingen:
Cells with tabs, or "tabbed cells", are available from many suppliers. DO NOT SOLDER DIRECTLY TO LITHIUM ION CELLS! They can and will explode.
door
Absolutely! Mr M Nunberg is 100 percent right. I've replaced my batteries twice since iv had mine
door
Voeg je antwoord toe
Jonathan Meeks zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 190
Altijd: 6,177
